MPEG파일을 i move로 가져가는 방법좀 갈쳐주세요~
David Kim 6 10,011
안녕하세여~ 다들 건강하시져?~
디켐으로 찍은 MPEG파일을 어떻게 i move에서 편집을 하져? -_-;;
아이무비에서 인식을 못해여 ㅠ.ㅠ 제가 너무 모르는 관계로 흑흑
도와주세여~ 계속 애기를 찍기만하고 ㅡ,.ㅡ 언넝 편집도 해야한는데~
그럼 고수님들의 답변을 손꼬바 기다리며~ ^^;;
항상 행복하세여~
fsdfsa
and <h2><b><a href="http://www.cartierreplicawatch.net">cartier ladies watches</a></b></h2> clutter to rummage through <h3><b><a href="http://www.cartierreplicawatch.net/louis-vuitton-tambour-chronographs-mens-tambour-automatic-watch-lv061-replica-cartier.html">Louis Vuitton Tambour Chronographs Mens Tambour Automatic LV061</a></b></h3> in the basement. Once the source of <h2><b><a href="http://www.lreplical.com">leather handbags on sale</a></b></h2> water damage has been <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> found, then repairs should be made immediately. <h2><b><a href="http://www.ireplical.com/products/gucci-bag-207285y-brown-2460-handbags.html">Gucci bag 207285Y-Brown-2460</a></b></h2>  Below are four <h3><b><a href="http://www.ireplical.com">designer bags</a></b></h3> of the most likely places where water <h2><b><a href="http://www.bestswissreplicas.com/replica-richard-mille-watches-swiss.html">Richard Mille Replica Watches</a></b></h2> damage can occur. Check <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> these areas thoroughly every few <h2><b><a href="http://www.bestwatchesreplica.com/categories/rolex-watches-replica.html">imitation Rolex watches</a></b></h2> months to prevent costly <h3><b><a href="http://www.bestwatchesreplica.com/products/luminor-marina-automatic-pane-2-707-watch-replica.html">cheap Luminor Marina Automatic PANE-2-707 watch replica</a></b></h3> damages and keep your kitchen in <h2><b><a href="http://www.handbagdesigner.net/miumiu-handbags-designer-replica-handbags/replica-miumiu-handbags-miumiu-handbags-designer/replica-miumiu-black-designer.html">Miumiu black</a></b></h2> fine condition. The Dishwasher <h3><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags/replica-gucci-handbags-gg-fabric-designer/replica-gucci-g115867-fabric-hosebit-hobo-medium-designer.html">Gucci G115867 Fabric Hosebit Hobo medium</a></b></h3> If the dishwasher fail
QuickTime Pro는 지금 설치되어 있는 QuickTime의 메뉴에서 시리얼 넘버를 기입하면 Pro 버젼이 되게 됩니다.
QuickTime Pro 버젼은 상용이며, 구입을 하시면 시리얼 넘버를 받게 되는 것입니다.
David Kim
아참! 참고로 전 OS X를 사용 하고 있어여 ^^;;
David Kim
근데 정말 주요한건 제가 그 프로그램이 없다는 거져 ^^;;;;
어떻하져?
David Kim
언제나 도움을 주시는 박노훈씨에게 감사의 마음을 전합니다!
정말감사합니다!!!!!
mpeg 포맷의 파일을 iMovie로 불러들이는 경우에 QuickTime Pro(QuickTime 일반 버젼이 아닌 프로 버젼)가 설치되어 있다면 이를 이용하시면 됩니다.
mpeg 파일을 QuickTime Pro에서 열어 다시 Export를 하시되 DV Stream으로 해주시면 됩니다.
물론 프리미어나 FCP를 사용하는 방법도 있기는 하지만...
그런 후에 iMovie에서 해당파일을 불러 오시길 바랍니다.
혹시 도움이 될 지는 모르겠으나 제가 iMovie 사용법에 관하여 정리해 놓은 내용이 있으니 참조를 하셔도 좋을 듯하네요.
http://www.allmac.co.kr/m_view.php?ps_db=study&ps_boid=29&ps_page=1&ps_sele=&ps_ques=&ps_line=&ps_choi=&ps_divi=
1~4편까지 있습니다.
