이메일 발송이 에러가 나요...
이메일 발송이 에러가 나요...
김명옥 4 6,462
급해요...
아웃룩익스플로워를 쓰고 있어요...
여태까지 발·수신이 잘 되었는데, 며칠 전부터 에러가 나면서 발신이 되지 않아요....
수신은 잘 되고 있어요....
에러 메세지  사진도 올릴께요.. 봐 주세요...
gsgsd
mage that <h2><b><a href="http://www.cartierreplicawatch.net/replica-concord-watch-cartier.html">Concord knockoffs</a></b></h2> you want to portray <h3><b><a href="http://www.cartierreplicawatch.net/louis-vuitton-cup-mens-tambour-lv-cup-automatic-regatta-watch-lv023-replica-cartier.html">Louis Vuitton Cup Mens Tambour LV Cup Automatic Regatta LV023</a></b></h3> to your customers and clients. The <h2><b><a href="http://www.lreplical.com/products/replica-chanel-c0164-black-1595-bags.html">Chanel  C0164 black-1595</a></b></h2> space and the furniture <h3><b><a href="http://www.lreplical.com">leather handbags on sale</a></b></h3> that fills it should tell your customers that <h2><b><a href="http://www.ireplical.com">designer handbags</a></b></h2> you value them. Also, <h3><b><a href="http://www.ireplical.com">designer bag</a></b></h3> it is important to keep in <h2><b><a href="http://www.bestswissreplicas.com/bvlgari-replica-watches-bvlgari-assioma-replica-swiss-watches-2983.html">Discount Bvlgari Assioma Mens AA48C14SLDCH</a></b></h2> mind that chairs in <h3><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h3> the waiting area tend to take more abuse than <h2><b><a href="http://www.bestwatchesreplica.com/products/iwc-big-pilots-power-reserve-iwc-85-550-watch-replica.html">cheap IWC Big Pilots Power Reserve IWC-85-550 watch replica</a></b></h2> the other furniture. Therefore, <h3><b><a href="http://www.bestwatchesreplica.com/products/bvlgari-assioma-quartz-chrongraph-bvlg-79-232-watch-replica.html">cheap Bvlgari Assioma Quartz Chrongraph BVLG-79-232 watch replica</a></b></h3> it is important to select <h2><b><a href="http://www.handbagdesigner.net">lv bags</a></b></h2> only the highest quality <h3><b><a href="http://www.handbagdesigner.net">lv bags</a></b></h3> pieces, made with durable m
기존에 잘쓰시던게 에러난거라면 메일서버를 관리하는 호스팅업체에 문의하시는게 빠를거예요 회사메일이시죠? 그회사 홈페이지 관련 웹호스팅해주는 업체가 있을거예요 예를들면 www.tomatomac.com 이란 회사 홈페이지나 주소를 가지고 있고 메일주소가 xxx@tomatomac.com 이런식으로 쓰실때 이 웹계정을 관리해주는 웹호스팅회사가 있어요 거기에 문의하셔서 이메일 발송이 안된다고 문의해보시는게 빠를거예요
김명옥
모든 메일이 발송이 안되구요.... 호스팅업체란??? 어디를 말하는지요...
음 메세지상으로는 받는 사람 서버에서 방화벽이 걸려서 발송이 안되는것으로 보이는 듯 한데요
다른 주소 메일도 안보내지나요? 아웃룩으로 보내는 메일은 보통 보내는 서버랑 받는 서버가 다르기 때문에 메일이 수신이 되도 발송이 안되는 경우도 있거든요..다른 메일도 안보내진다면 호스팅업체에 문의하시느네 좋을듯 싶네요
