아이비엠일러에서펜툴로 이미지를따고..
김한솔
4,343
2010.01.25 21:52
jpg저장을 했는데 쿽에서 불러오니 엄청깨지고 이상한 색상이 들어가있네요
어떤분께서 tif 파일로 저장하는게 아니고 jpg/8비트라고 써놓으신걸 봤는데
tif/8비트 밖에 없던데 어떻게 해야하나용..ㅠ
replica watch
2010.04.10 18:39
<a href="
http://www.discountwatchmvp.com/products/bvlgari-101213-1472.html"
>Ergon Steel Chronograph Black Mens Watch 101213-2327</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-eg40bsld-1473.html"
>Mens Watch EG40BSLD-2328</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-eg40bssd-1474.html"
>Bulgari Ergon Stainless Steel Mens Watch EG40BSSD-2329</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-eg30bssd-1476.html"
>Ergon Ladies Watch EG30BSSD-2330</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-eg35bsldch12-1477.html"
>Ergon Mens Watch EG35BSLDCH12-2331</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-eg35bssdch-1478.html"
>Ergon Mens Watch EG35BSSDCH-2332</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-rtc49svd--1479.html"
>Rettangolo Watch RTC49SVD--2333</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-rtc49svd-1480.html"
>Rettangolo Watch RTC49SVD-2334</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-rt39bss-1481.html"
>Rettangolo Watch RT39BSS-2335</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-rt39sl-1482.html"
>Rettangolo Watch RT39SL-2336</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-rt45c6lssd-1483.html"
>Rettangolo Watch RT45C6LSSD-2337</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-rtc49gld-1484.html"
>Rettangolo Mens Watch RTC49GLD-2338</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-101181-1485.html"
>Rettangolo Steel and Black Rubber Mens Watch 101181-2339</a>
<a href="
http://www.discountwatchmvp.com/products/bvlgari-rtw39gd1g-1487.html"
>Rettangolo Ladies Watch RTW39GD1G-2340</a>
<a href="http://www.discountwatchmvp.com/products/bvlgari-101213-1472.html">Ergon Steel Chronograph Black Mens Watch 101213-2327</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-eg40bsld-1473.html">Mens Watch EG40BSLD-2328</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-eg40bssd-1474.html">Bulgari Ergon Stainless Steel Mens Watch EG40BSSD-2329</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-eg30bssd-1476.html">Ergon Ladies Watch EG30BSSD-2330</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-eg35bsldch12-1477.html">Ergon Mens Watch EG35BSLDCH12-2331</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-eg35bssdch-1478.html">Ergon Mens Watch EG35BSSDCH-2332</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-rtc49svd--1479.html">Rettangolo Watch RTC49SVD--2333</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-rtc49svd-1480.html">Rettangolo Watch RTC49SVD-2334</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-rt39bss-1481.html">Rettangolo Watch RT39BSS-2335</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-rt39sl-1482.html">Rettangolo Watch RT39SL-2336</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-rt45c6lssd-1483.html">Rettangolo Watch RT45C6LSSD-2337</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-rtc49gld-1484.html">Rettangolo Mens Watch RTC49GLD-2338</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-101181-1485.html">Rettangolo Steel and Black Rubber Mens Watch 101181-2339</a> <a href="http://www.discountwatchmvp.com/products/bvlgari-rtw39gd1g-1487.html">Rettangolo Ladies Watch RTW39GD1G-2340</a>
2010.01.26 00:28
emoticon_096 jpg/8비트로 저장하라는것은 포토샵에서 EPS로 저장시에 프리뷰(미리보기) 옵션을 그렇게 하라는 애기입니다
포토샵 저장시에 대화상자에 보시면 있습니다.
그리고 쿼크3.3에서는원래 이미지들이 좀 거칠고 매끄럽게 보이지를 않습니다.
하지만.. 출력시에는 상관이 없습니다.
원본 이미지데이타만 이상없이 깨끗하다면 그대로 출력이 깨끗하게 되거든요..
emoticon_096 jpg/8비트로 저장하라는것은 포토샵에서 EPS로 저장시에 프리뷰(미리보기) 옵션을 그렇게 하라는 애기입니다 포토샵 저장시에 대화상자에 보시면 있습니다. 그리고 쿼크3.3에서는원래 이미지들이 좀 거칠고 매끄럽게 보이지를 않습니다. 하지만.. 출력시에는 상관이 없습니다. 원본 이미지데이타만 이상없이 깨끗하다면 그대로 출력이 깨끗하게 되거든요.. ========= ▷▶☎ 잘 해결이 안되신다면.. 준[A/S 판매]를 클릭후 <자기 소개>를 마우스로 눌러보세요.
2010.01.26 10:56
음 IBM용 퀵을 쓰시나요? 맥용 퀵을쓰신다면
IBM일러나 포토삽에서 저장하신걸 그대로 쓰시면 맥용 퀵에서 미리보기가 나오질않아요
이걸 다시 맥용 일러나 포토삽에서 프리뷰를 맥으로 잡아주시고 다시 저장해야 퀵도큐에서 미리보기가 제대로 나와요.그리고 퀵에서는 EPS나 Tif등으로 저장하셔야 제대로 보여요..JPG도 보이긴하는데요 엄청버벅 되요 ㅎㅎㅎ
음 IBM용 퀵을 쓰시나요? 맥용 퀵을쓰신다면 IBM일러나 포토삽에서 저장하신걸 그대로 쓰시면 맥용 퀵에서 미리보기가 나오질않아요 이걸 다시 맥용 일러나 포토삽에서 프리뷰를 맥으로 잡아주시고 다시 저장해야 퀵도큐에서 미리보기가 제대로 나와요.그리고 퀵에서는 EPS나 Tif등으로 저장하셔야 제대로 보여요..JPG도 보이긴하는데요 엄청버벅 되요 ㅎㅎㅎ
200 명
2,902 명
2,926 명
14,908,616 명
